Ele é mesmo burro e comprou aquilo a pensar que é um Rally. Alguém trocou as peças de um.
Não tem mal...
Há que perceber é que não nasceu assim. O pedal de acelerador específico por exemplo era fácil trocar. Até o charrion não é o mesmo.
E pior foi mexer em geometria de suspensão e travões.
1 legend rally front, wrong place
2 front badge plastic, 1972 metal and bigger (72mm)
3 side flashers wrong
4 front metal panel early 128
5 bumper holes covered
6 front bumper missing. It's hornless rhinoceros
7 side skirts, wrong curvature
8 wrong wheels 4x100?
9 wrong Wheel bolts
10 wheel center different
11 side sticker Rally, wrong place, format
12 rear side glass aftermarket (rally no bolts)
13 stainless trim in front/reat windows (rally and early 1100 only)
14 wrong gas cover
15 no rear bumper
16 front light fiat 128 1100.
17 Missing auxiliary lights rally only
18 wrong srews front grille
19 door covers brown, rally black
20 left and right glass lever different
21 SEATS 128 1100 (rally black = fiat 124 spider)
22 wrong rubber doors
23 missing floor/carpet/door trim
24 No rally Carpet, is specific
25 wrong gear lever, color and size
26 Gas pedal 1100. Rally special pedal to Heel and Toe
27 wrong air handle, 1 1972, other early
28 air vents no chrome
29 rear astray black
30 missing cover handle
31 hanger from Sport Coupe
32 wrong steering wheel, rubber black
33 wheel center red early Rally
34 missing fuse cover
35 painted door switch and door turnbuckles
36 Missing center console (only in Rally)
37 handbrake black and missing rubber
38 no jack in rear trunk
39 trim rear arch inside truck
40 spring trunk black
41 rear seat inside trunk grey
42 fuel pump trunk?
43 AA bar will induce rigidity and tear chassis
44 wrong exit from engine to Chauffage
45 missing timing belt cover
46 Double weber + original head?
47 no Chauffage air box
48 abarth cover made in china
49 lowered rear
50 radiator cover wrong
51 radiator fan, no 1972
52 dog bone engine support wrong
53 rubber bonnet, no original
54 wrong brake pipe type and place
55 missing spare tyre
56 oil cover engine color
57 REAR BRAKE DISTRIBUTOR OFF!!!
58 Spring front and rear no original
59 RALLY two pipes side by side under the car (gas return)
60 Oil Pan from Fiat x1/9
61 Wrong electric instalation (Rally -relay near top suspension)
62 Transverse spring/leaf removed!!!
63 NO FRONT ENGINE PROTECTON Specific rally
64 Rear disc brakes
65 Cross menber engine support 1100
66 ground cable wrong place
67 engine support/gearbox damaged
68 ID plate "AR" cleaned
69 no central exhaust
70 wrong exhaus manifold
71 gear box without reverse sensor (rally and Coupe)
72 inside roof white. Rally all black
73 sunvisors black in rally
74 Fuel pump wrong
75 engine pulleys plastic? after 1973
76 Pillar A and C missing plastics
77 top front suspension
78 engine not 1972 version
79 mudflaps
80 no metal plates to lock charrion screws
81 oil dipstick wrong
82 servo brake wrong color
83 tank cover from other car
84 wrong steering terminal
85 exhaust union
86 exhaust breather tube
87 wrong silent blocks
88 no gas tank rubber protection
89 plate hole removed
90 no plastic rear front grille
91 no plate light
92 glass front and rear rubber 3ºserie 128
93 missing manual pump water glass
94 no lateral inox trim (all 128)
95 no original rubber floor trunk
96 wrong termostat
97 front axle made after 1973
98 front bumper made after 1973
99 rubber trunk stops
100- no vin number AR
