Cisitalia D46
Conta apagada 31475
Antes Francisco Lemos Ferreira
CISITALIA D-46
General specifications
Country of origin Italy
Chassis number 0020
Numbers built 31
Produced from 1946 - 1948
Engine
Configuration Fiat Straight 4
Location Front, longitudinally mounted
Displacement 1.089 liter / 66.5 cu in
Bore / Stroke 68.0 mm (2.7 in) / 75.0 mm (3 in)
Compression 9.5:1
Valvetrain 2 valves / cylinder, OHV
Fuel feed Zenith 30 VIF/C Carburettor
Aspiration Naturally Aspirated
Drivetrain
Chassis/body aluminium body on tubular chassis
Front suspension lower arms, transverse semi-elliptic leaf spring, hydraulic dampers
Rear suspension live axle, semi-elliptic leaf springs, friction dampers
Steering worm-and-sector
Brakes drums, all-round
Gearbox preselector 3 speed Manual
Drive Rear wheel drive
Dimensions
Weight 370 kilo / 815.7 lbs
Length / Width / Height 3000 mm (118.1 in) / 1400 mm (55.1 in) / 1020 mm (40.2 in)
Wheelbase / Track (fr/r) 2050 mm (80.7 in) / 1225 mm (48.2 in) / 1125 mm (44.3 in)
Performance figures
Power 62 bhp / 46 KW @ 5800 rpm
BHP/Liter 57 bhp / liter
Power to weight 0.17 bhp / kg
Top Speed 170 km/h / 106 mph
in "ultimatecarpage.com"
    207.8 KB · Vistos: 0
    213.8 KB · Vistos: 0
    183.5 KB · Vistos: 0
    186.7 KB · Vistos: 0
    155 KB · Vistos: 0
    155 KB · Vistos: 0
    155 KB · Vistos: 0
    155 KB · Vistos: 0
    155 KB · Vistos: 0
    155 KB · Vistos: 0
    155 KB · Vistos: 0
    155 KB · Vistos: 0
    155 KB · Vistos: 0
Isto sim são grandes maravilhas do século passado, grandes tempos e pena não haver mais espírito assim :Dgear_wink2:
Se bem que deverias colocar estas máquinas num tópico só, ou não?!;)
somente para não andar perdido, pois estes carros já me tiram do sério:D
C
Conta apagada 31475
Não João pois se fizeres uma busca no google por cada um dos modelos aparece o Portal se tiverem todos num tópico não;)
