ajuda motor datsun 1200
MiguelGT
boa noite
preciso de uma ajuda vou instalar um duplo weber 40 mais coletores escape trufeo
e vou mandar dar uma toque na arvore de cam mas preciso de uma ajuda tambem vou prescisar de ajustar as valvulas ? sendo que a medida de fabrica e 0,35 mm pois de instalar tudo fica com as mesma medias ?
comprimentos
boa noite
comprimentos
Não percebo muito disso, mas quase de certeza que sim...
Luis Antonio Cardoso
Viva ,
Pode ser que ajude:
Cold Setting
Per Nissan:
Setting clearance on cold valves is recommended only as an initial step -- for example, after assembling a cylinder head. At all other times, set clearances only when the valves are hot
  • 1971 COLD: 0.35 mm (14 thousands inch)
  • 1973 COLD: 0.25 mm (10 thousands inch)
  • Test COLD: 0.33 mm (13 thousands inch)
NOTE: The 1971 manual (in the text) has the cold specification at 0.35 mm but at 0.25 in the Specifications. The 1973 manual lists it at 0.25 mm. Either one works OK, but Nissan recommends resetting lash after getting engine to full temperature (set it HOT).
The Service Bulletin confirms the .25 mm COLD setting. In my personal tests (multiple tests) of HOT setting at .35 then letting the engine cool overnight, it returns to a .33 COLD -- so I've been setting it to .33 COLD for the last 25+ years with great success (I've never had a valve problem).
Corrected by Service Bulle
