O Meu futuro Clássico BMW...
Tópico em 'Clássicos Modernos' iniciado por Marco Pestana, 14 Mar 2008.
  1. Marco Pestana
    Marco Pestana MarcoSprint MarcoVW61
    19 Jun 2006
    Ilha da Madeira
    O Meu futuro Clássico BMW E30 320iS
    Um futuro e cada vez mais raro ( futuro ) clássico:
    BMW E30 320iS S14B20 M Power 192cv 1988 ( ano Produção )
    Caixa GETRAG Dog-Leg "Close ratio"
    LSD
  2. Paulo Baião
    Paulo Baião Clássico
    1 Ago 2007
    Charneca de Caparica
    Essa 1ª para trás é que me mata!!!
    Fantástico carro, tive a oportunidade de conduzir um e adorei.
    Também conduzi um 323i E30 com a mesma caixa, motor mexido pela Schnitzer, também muito bom.
  3. Diogo Lisboa
    Diogo Lisboa Veterano
    1 Set 2006
    Leiria
    Parabéns!! O BMW é fantástico!:D
  4. Francisco Lemos Ferreira
    Staff Portalista
    8 Fev 2007
  5. Marco Pestana
    19 Jun 2006
    Ilha da Madeira
    Oh Amigo Francisco!
    Aos anos que eu tenho o BMW E30 320iS! :D:D:D
    Esta na minha " Garagem"...
    Marco
  6. Marco Pestana
    19 Jun 2006
    Ilha da Madeira
    História do BMW E30 320iS
    BMW E30 320iS S14 M Power Nobre Desconhecido - alguns dados interessantes sobre este modelo, construído em exclusivo para Portugal e Itália.
    Production Versions: AK95: Italy and Portugal-spec two-door, 11/87-11/90 AC95: Italy and Portugal-spec four-door, 09/87-07/90
    History
    What makes the E30 320is unique?
    The E30 320is is a special 3 Series model that was sold exclusively in Italy and Portugal in order to take advantage of the reduced taxes in those countries for cars with engines that displace two liters or less. It is powered by a 1990cc version of the four-cylinder S14 engine developed by BMW Motorsport for the E30 M3 and also shares its close-ratio Getrag gearbox with the M3. However, all other components are standard 3 Series items.
    Where was the E30 320is built?
    The E30 320is was built on the normal Regensberg assembly line alongside the other 3 Series models. If the E30 320is is powered by an M engine, why is not badged as an M model? The reason the E30 320is is not badged as an M model ultimately comes down to marketing: Unlike the limited-production M3, which was created primarily as a competition machine and utilizes many unique exterior body panels and chassis components, the 320is was never intended to be a homologation special. It was conceived instead as a sportier and more affordable alternative to the torquier and more refined 325i, which was taxed heavily in Italy and Portugal due to its 2.5-liter engine.
    Production Data
    How many versions of the E30 320is were developed?
    BMW developed the E30 320is only in non-catalyst, left-hand drive form and exported it exclusively to Italy and Portugal. Both two-door and four-door body styles were offered. How many of each version were produced? Two-door: 2,540 built from 11/87 thru 11/90 Four-door: 1,206 built from 09/87 thru 07/90
    What changed during the production of the E30 320is?
    There were no mechanical changes to the E30 320is during the three years that it was produced. However, there were a number of minor cosmetic and equipment variations that also apply to every E30 3 Series model built during the same period. Drivetrain What makes the two-liter S14 engine unique? The two-liter S14 engine in the E30 320is is essentially identical to the 2,302cc version found in the E30 M3 except for its shorter stroke (72.6mm versus 84mm) that yields an overall displacement of 1,990cc. Like all S14 engines, it combines the basic four-cylinder block from the M10 family with a four-valve head derived from the one used on the six-cylinder M88 and S38 motors. Special features of this engine include individual throttle plates for each cylinder, machined intake and exhaust ports, and a crankshaft with eight counterweights. Like the M88 and S38, the S14 does not have hydraulic lifters, and thus requires periodic valve adjustments. The two-liter S14 is rated at 192 hp (DIN) at 6,900 rpm and 155 lb/ft of torque at 4,900 rpm. This is down slightly compared to the non-catalyst, 2.3-liter S14 used in the E30 M3 which is rated at 200 hp (DIN) at 6,750 and 176 lb/ft of torque at 4,750 rpm. The S14 engine fitted to the 320is has an identical appearance to the unit found in the E30 M3 and thus shares the "BMW M Power" inscription on its cam cover.
    What kind of gearbox does the E30 320is have?
    Like the European-spec E30 M3, the sole gearbox for the E30 320is is a close-ratio Getrag 260 five-speed manual with a "dogleg" shift pattern and the following ratios: 3.72 (1), 2.40 (2), 1.77 (3), 1.26 (4), 1.00 (5). This is mated to a shorter (compared to the M3) 3.46:1 rear axle ratio with limited-slip differential. Chassis How is the suspension of the E30 320is different from that of a standard E30 3 Series? Like all E30 3 Series, the suspension of the 320is consists of a MacPherson strut/semi-trailing arm design. However, the springs, shocks and anti-roll bars are of the more aggressive "Sportfahrwerk" specification, also offered on other E30 models such as the UK-spec 325i Sport.
    What kind of steering does the E30 320is have?
    The 320is uses the standard E30 power-assisted rack-and-pinion steering system with an overall ratio of 20.5:1. What size brakes does the E30 320is have? The E30 320is shares its braking system with the six-cylinder E30 models and thus is equipped with 10.2-inch (260mm) vented disc brakes in the front and 10.2-inch (260mm) solid disc brakes in the rear. ABS was fitted as standard equipment.
    What are the factory wheel and tire sizes for the E30 320is?
    The E30 320is is equipped exclusively with 195/65VR14 tires. These are mounted to one of two different alloy wheel designs, both of which were shared with other E30 3 Series models: The 6.5x14-inch cross-spoke wheel (standard on the two-door) or the more plain 6x14-inch alloy (standard on the four-door).
    Cosmetics How is the exterior of the E30 320is different from that of a regular 3 Series?
    The exterior of the 320is can only be identified from other E30 3 Series models by its "320is" badging on the trunk lid, though this could be deleted upon request. (The curved dual exhaust tips are also unlike those of any other four-cylinder 3 Series but are shared with the six-cylinder E30 325i.)
    What items were fitted as standard equipment to the exterior of the E30 320is?
    The exterior of the four-door E30 320is is equipped only with fog lights, 14-inch alloy wheels and a body-color rear spoiler. The two-door version adds the complete M-Technic II aero package (identical to the one fitted to the UK-spec 325i Sport and available as an accessory on all other E30 3 Series models), which consists of a deeper front airdam, additional lower side body panels, an extended valance under the rear bumper and a two-piece rear spoiler. In addition, the two-door E30 320is is also equipped with body-color rearview mirror housings, Shadowline (dechromed) window trim and 14-inch cross-spoke alloy wheels for a sportier appearance. How is the interior of the E30 320is different from that of a regular 3 Series? The interior of the E30 320is is identical to that of other 3 Series models with the sole excpetion of its unique instrument cluster that utilizes the same tachometer with integrated oil temperature gauge as the E30 M3, but lacks the red needles and M logo between the two main dials. Also, the gear shift knob is of the older non-ergonomic design that was phased out on other E30 3 Series models (with the exception of the M3) in September, 1987.
    What interior features were included as standard equipment on the E30 320is?
    The interior of the four-door E30 320is is quite Spartan, offering only the basics such as power mirrors, central locking and a rear-window defroster as standard equipment. The two-door model adds map lights in the rear view mirror, sport seats, a three-spoke leather-wrapped M-Technic steering wheel and a leather shift knob. Factory options for both two-door and four-door versions of the 320is included: air conditioning, power windows, manual sunroof, power sunroof, digital clock, on-board computer and leather upholstery.
    Special Versions Were there any special editions of the E30 320is?
    There were no factory special editions of the E30 320is. Color and Upholstery Selections Exterior Colors: Alpine White II (218), Cinnabar Red* (138), Brilliant Red** (308), Diamond Black metallic (181), Delphin Grey metallic (184), Salmon Silver metallic *(203), Sterling Silver metallic** (244) *Thru 8/89 **From 9/89 Interior Colors: Anthracite cloth, Grey cloth, Natur cloth, Black leather, Cardinal Red leather, Natur leather, Silvergrey leather
    Fonte : www.BMWMregistry.com
  7. José Guimarães
    3 Jan 2007
    LORDELO PAREDES
    de facto cada vez mais raros e consequentemente mais caros !!!
    O teu esta muito giro e bem conservado!!!
  8. José Guimarães
    3 Jan 2007
    LORDELO PAREDES
    Marco Porque nao os piscas laranja a frente , umas matriculas de fundo preto e umas jantes bbs
  9. Francisco Costa
    14 Mar 2007
    Gondomar
    Parabéns Marco!!
    Tenho um amigo que tem 2 320is e quando olho para os carros fico com uma inveja... :D
    De facto este E30, é um modelo muito desejado, mas também muito caro!! Tem um motor muito bom e posso estar enganado, mas penso que tenho um comportamento mais equilibrado do que o M3.
    Tens uma bela colecção!!
  10. Marco Pestana
    19 Jun 2006
    Ilha da Madeira
    Obrigado caro amigo;
    Podes verificar todas as caracteristicas deste modelo especial M BMW.
    É um autêntico M3 "off-market" da BMW, para " enganar " os impostos altíssimos para automóveis acima dos 2000cc em Portugal e Itália.
  11. Marco Pestana
    19 Jun 2006
    Ilha da Madeira
    Nem mais!;)
    Só mesmo conduzindo um E30 320iS para saber como é...Em especial o " disparo" acima das 4000rpm!;)
    E com motor atmosférico...;)
  12. Marco Pestana
    19 Jun 2006
    Ilha da Madeira
    Obrigado! ;)
  13. Marco Pestana
    19 Jun 2006
    Ilha da Madeira
  14. Jose Tomas
    Jose Tomas YoungTimer
    11 Fev 2006
    Sintra
    Bela maquina ,Marco.:feliz:
  15. Marco Pestana
    19 Jun 2006
    Ilha da Madeira
    Os piscas por mania! ;)
    As 5 jantes BBS originais tenho guardadas.
    Neste momento tem umas Millie Miglia 16"
  16. Marco Pestana
    19 Jun 2006
    Ilha da Madeira
  17. José Guimarães
    3 Jan 2007
    LORDELO PAREDES
    Tava a ver que nao respondias marco!!:D
    Se calhar nao devia ter feito comentario!!!:huh:
    Mas como tens os teus carros com grandes pormenores de cuidados esteticos ...
    muito interessante esse site do registo....e muitos nacionais IS nacionais registados
  18. Marco Pestana
    19 Jun 2006
    Ilha da Madeira
    Obrigado Tomás! ;)
  19. José Guimarães
    3 Jan 2007
    LORDELO PAREDES
    A quantos anos tens o carro marco
  20. Marco Pestana
    19 Jun 2006
    Ilha da Madeira
    O BMW E30 320iS sempre esteve cá na "garagem" do Portal dos Clássicos...;)
    Até julgava que não fosse novidade...o_O
    Tenho-o desde 2003.
