Mini Austin Cooper S
Tópico em 'Mecânica' iniciado por Ricardo Nobre, 6 Nov 2006.
  1. Ricardo Nobre
    Ricardo Nobre Clássico
    30 Out 2006
  2. Rui Rego
    Rui Rego bmw2002t
    22 Jul 2006
    Portimão
    Parabens pelo restauro.
  3. Luis Silveira
    Luis Silveira Clássico
    10 Jul 2006
    Tenta contactar " www.minishop-portugal.com" que fica na Marinha Grande e dar o maior número de dados possivel.Devem poder dar-te informações.
    Cump.
    Luis
  4. Tiago Freire
    Tiago Freire YoungTimer
    3 Jul 2006
    Brejo
    Boas.
    Para saberes que motor tens não tens de abrir o motor.
    Primeiro aqui estão todos os números de motor de todos os minis:
    Small Bore
    8A/UH 848 A/A2S7 Austin Mini 850 (UK)
    M/A2S4 Morris Mini 850 (UK)
    8AH/ 848 ? Mini Automatic (UK)
    8AJ/We/101 848 ? Mini (UK)
    8AM/U/H 848 YMA2Sl Morris Mini Saloon (A)
    8AM/U/H 848 YJBAV2R Morris Mini Van (A)
    8AM/Te/101 848 ? Mini (UK)?
    8AM/We/101 848 ? Mini (UK)?
    8MB/U/H 848 A/A2S7 Austin Mini 850 (UK)
    R/A251 Mkl Riley Elf (UK)
    W/A251 Mkl Wolseley Hornet (UK)
    8Y/U/H 848 YMA2S3 Morris Mini Saloon (A)
    85H/ 848 ? Mini (UK)?
    9AG/ 998 ? Mini
    9AN/A/H 998 YMA2S4 Morris Minimatic Early Mkl(A)
    9F/Sa/K 998 ? Morris Cooper (UK)
    9F/Sa/H 997 C/A2S7 Austin Cooper (H/Comp) (UK
    9F/Sa/H 997 K/A2S4 Morris Cooper (H/Comp) (UK)
    9F/SajH 997 YKA2S1 Morris Cooper (H/Comp) (A))
    9F/Sa/L 997 C/A2S7 Austin Cooper (L/Comp) (UK)
    9F/Sa/L 997 K/A2S4 Morris Cooper (L/Comp) (UK)
    9F/Sa/L 997 YKA2S1 Morris Cooper (L/Comp) (A)
    9FA/Sa/H 998 C/A2S7 Austin Cooper (H/Comp) (UK)
    9FA/Sa/H 998 K/A2S4 Morris Cooper (H/Comp) (UK)
    9FA/Sa/H 998 YKA2S1 Morris Cooper (H/Comp) (A)
    9FA/Sa/L 998 C/A2S7 Austin Cooper (L/Comp) (UK)
    9FA/Sa/L 998 K/A2S4 Morris Cooper (L/Comp) (UK)
    9FA/Sa/L 998 YKA2S1 Morris Cooper (L/Comp) (A)
    9FD/Sa/H 998 C/A2S7 Austin Cooper (H/Comp) (UK)
    9FD/Sa/H 998 K/A2S4 Morris Cooper (H/Comp) (UK)
    9FD/Sa/L 998 C/A2S7 Austin Cooper (L/Comp) (UK)
    9FD/Sa/L 998 K/A2S4 Morris Cooper (L/Comp) (UK)
    9FD/Xe/ 998 ?
    9FX/Xe/H 998 ? Morris Cooper (UK)
    9H/Sa/ 998 ? Morris Cooper (UK)
    9WR 998 ? Mini 1000,
    R/A2S2 Mk2/3 Riley Elf and
    W/A2S2 Wolseley Hornet (UK)
    9Y/ 998 ? Morris Cooper (UK)
    9Y/Sa/H 998 ? Morris Cooper (UK)
    9YA/Ta/H 998 YMA2S2 Morris Mini Deluxe (A)
    9YA/U/H 998 ? Morris Mini Deluxe (A)
    9YBj 398 ? Moke (UK)7
    9YE/U/H 998 YMA2S3 Morris Mini Saloon (A)
    9YE/U/H 998 YJBAV2 Morris Mini Van (A)
    9YH/ 998 ? BMC Moke (UK)
    99H/119/H 998 YMA2S4 Morris Minimatic Late Mkl (A)
    l0Y 1100 ? Morris Mini Saloon (A)
    l0YC 1100 ? Morris Mini Saloon (A)
    l0YF 1100 ? Moke (A)
    l0YJ/U/H 1100 YMG2S4 Morris Mini ####(A)
    l0YJ/U/H 1100 YAG2S4 Morris Mini ####(A)
    l0YJ/U/H 1100 YJBAV4 Morris Mini Van Mk2 (A)
    l0YM 1100 ? Morris Mini Saloon (A)
    l0YN 1100 ? Morris Mini ####(A)
    1000 - 1100 1100 ? Saloon and Van (A)
    1001 1100 ? Mini Clubman Saloon (A)
    A/AW7
    M/AW4
    A/A2SB
    X/A2S2
    XAD2
    XADL
    850 D20S Mini (UK)
    998 N20S Mini (UK)
    S20S Mini Clubman Saloon (UK)
    20W Mini Clubman Estate (UK)
    Big Bore
    9F/Sa/X 970 C/A2S7 Austin Cooper 'S' (UK)
    9F/Sa/X 970 K/A2S4 Morris Cooper 'S' (UK)
    9FC/ 970 ? Morris Cooper 'S' (UK)
    9F/Sa/H 1071 C/A2S7 Austin Cooper 'S' (UK)
    9F/Sa/H 1071 K/A2S4 Morris Cooper 'S' (UK)
    l0F 1071 ? Morris Cooper 'S' (UK)
    9F/Sa/Y 1275 C/A2S7 Austin Cooper 'S' Mkl (UK)
    9F/Sa/Y 1275 K/A2S4 Morris Cooper 'S' Mkl (UK)
    9F/Xe/Y 1275 C/A2SB Austin Cooper 'S' Mk2 (UK)
    9F/Xe/Y 1275 K/A2S6 Morris Cooper 'S' Mk2 (UK)
    9F/Sa/Y 1275 YKG2S2 Morris Cooper 'S' Mkl (A)
    9F/Xe/Y 1275 YG2S4 Morris Cooper 'S' Mk2 (A)
    9F/Xe/Y 1275 XAD1 Morris Cooper 'S' Mk3 (UK)
    9F/Xe/Y 1275 YG2S8 Early Clubman 1275GT (A)
    (basically fitted with Mk2
    Cooper 'S'
    running gear)
    1200 1275 ? Clubman GT (A)
    1204 1275 ? Moke (A)
    12F 1275 ? Morris Cooper 'S' (UK)
    12FA 1275 ? ? (A)
    12H/389/SH 1275 S20D Mini 1275GT (UK)
    12Y 1275 ? Clubman GT or Moke (A)
    12YD/Ta/H 1275 ? Leyland 1275LS (12" Wheels)
    Here are some I.D. numbers to identify your or other engines.
    The numbers are the first 1 or 2 numbers followed by a letter.
    850 cc
    8 A austin
    8 MB morris
    8 AM austin/morris
    8 AH automatic
    8 AJ a/m closed circuit breather
    8 AK automatic , as above
    8 WR wolseley hornet, riley elf
    8 AC moke
    85 H/101 850 from 1969 on.
    998 cc
    9 WR wolseley hornet/ riley elf MK2, pre closed breathing.
    9 AD austin, wolseley, riley with remote gearbox closed
    circuit breathing.
    9 AE wolseley, riley MK 3
    99 H/-/101 on wolseley, riley, mini clubman, mini 1000 1970 on
    MK 3 dished dished piston.
    99 H/791 mini 1974 on dished piston.
    99 H/997 A+ block 1980 on, flat top piston, economy 2.95 ratio
    99 H/a97p A+, dished, pre A+ gears, 3.44 final drive,
    12" WHEELS.
    998 A+ block with central locating groove on maincap
    1985 on.
    FLAT TOP WITH CIRCLIP TYPE PISTON.
    99 H/B 81 to engine 127431
    99 H/C 20 to engine 105023
    99 H/997 from engine 127422, 2.9 final drive
    99 H/A53P
    FLAT TOP WITH PRESS FIT GUDGEON PIN PISTONS
    99 H/B81 from engine 127432
    99 H/C20 from engine 105024
    99 H/D80
    AS ABOVE, BUT LEAD FREE.
    99 H/G30/G32/G33
    99 H/F15/16
    99 H/D81
    LBB 10089
    1100 cc
    10 AMW/Ta clubman estate + austin 1100(ado 16)
    10 H 791 clubman saloon
    10 H/-/H all austin 1100cc 2/4 doors derivadates saloons
    10 GR/Ta/H MG 1100
    10 GRB/Ta/H MG 1100/wolseley 1100
    10 V/Ta/H vander plas 1100cc
    1275cc
    12 G/Ta/H 1275 `S` rods wolseley/MG/riley/vp 1300(ado16)
    12 H 379 1275 GT, dynamo, neg. earth, elec feul pump
    12 H 380 1275 GT, alternator, elec feul pump, remote box.
    12 H 389 as above but with dynamo
    12 H 390 GT with alternator
    12 H 706 GT with alternator, mech. feul pump, rod change
    12 H 397 Cooper S MK3, dynamo, neg. earth
    12 H 398 Cooper S MK3, alternator
    12 H/-/ 1275 Allegro, Austin 1300
    12 H 610/635 Innocenti with 11 stud and duplex gear
    12 H 719/832 Innocenti with 11 stud abd simplex gear
    997cc
    9 F/Sa/H
    998 cooper
    9 FA/Sa/H MK 1 Austin pre closed circuit breathing
    9 FD/Sa/H MK 1 Morris up to engineno. 1934, all
    austin MK2 closed circuit breathing
    9 FD/Sa/H Morris MK2 from engine no. 1935-33660
    9 FD/Xe/H 4 synchro gearbox introduced
    99 H/-/H Last of manifacture 1969
    970 cc S
    9 F/Sa/X 29001-29003 Tecalemit filter
    9 FD/Sa/X Closed circuit breathin introduced, Tecalemit filter
    9 FE/Sa/X Closed circuit, filter with oil switch introduced
    9 F/Sa/X Purolator filter with switch, closed circuit
    1070 cc S
    9 F/Sa/H
    9 FD/Sa/H closed cuircuit breathing with oil switch filter
    1275 cc S
    9 F/Sa/Y pre closed circuit breathing, purolator filter
    9 FD/Sa/Y closed circuit, oil switch on filter after No. 32178
    9 FE/Sa/Y as above but piston change
    9 F/Sa/Y as above but AEG 510 camshaft after engine 40006
    cross drilled EN 40 B crank, metal dipstick
    and tube
    12 H 397 MK3 S with dynamo, EN 16 crank - tuftrided
    12 H 398 MK3 S with alternator EN 16 crank - tuftrided
    Para saberes a diferença entre os motores podes ver esta página que está muito bem construída, só é pena estar em francês:http://www.mini-racing-garage.com/technique/menutech.php
    Como poderás verificar na página que indiquei as diferenças não são muitas, a única pode ser mesmo só na caixa e pouco mais.
  5. Ricardo Nobre
    30 Out 2006
  6. Tiago Freire
    3 Jul 2006
    Brejo
    Boas.
    Pois eu também já estive a ver e não encontrei nada com esse número.
    Já agora quantos pernos tem a apertar a cabeça?
    Não tires a tampa das válvulas, e conta os pernes. Se tiver mais dois pernos do lado direito e do lado esquerdo da cabeça, ou seja um ao pé da torneira da sofagem e outro ao pé da tampa do termostato, além dos 5 que tem à frente, então é sinal que deve ser de um cooper s.
    Mas se quiseres telefona-me quando estiveres ao pé do carro e eu tento dizer-te mais qualquer coisa, pois existem coisas que são dificeis de explicar aqui.
    O meu número é o 965554043.
  7. Ricardo Nobre
    30 Out 2006
  8. Hugo Uriel
    Hugo Uriel YoungTimer
    26 Jun 2006
    Montijo
    O motor que está na foto é de um Austin 1300GT, tambem tem 11 pernos, mas não é de um cooper s, qualquer das maneiras se me disseres a referencia que está no bloco (parte de trás) posso te dar a identidade correcta desse motor, ou então tira uma foto por trás ao motor.
    Em relação à caixa comecou a ser de 4 sincronizadas só nos MK2, os Mk1 eram todos de 3 sicronizadas.
    Este é um dos grandes problemas dos cooper s em portugal, poucos já tem o motor original.
    Se quiseres liga-me posso tentar ajudar no que precisares, é que tenho a mania que precebo de coopers lol. 936462424 ou uriel@clix.pt
    Espero ter ajudado
    Hugo
  9. Tiago Freire
    3 Jul 2006
    Brejo
    Boas, pois em princípio deve ser um motor de Austin sim.
    Mas se meteres ai mais fotos, inclusivé o número de caixa e do bloco, veêm-se mais características.
  10. Ricardo Nobre
    30 Out 2006
  11. Ricardo Nobre
    30 Out 2006
  12. Ricardo Nobre
    30 Out 2006
  13. Ricardo Nobre
    30 Out 2006
  14. Ricardo Nobre
    30 Out 2006
  15. Hugo Uriel
    26 Jun 2006
    Montijo
    Sendo assim tens mesmo o motor de um 1300GT.
    Em relação à cabeça é bastante relativo porque existe mais que uma 12G940.
    No entanto a cabeça do 1300GT é igual à do cooper s MK3, e como o motor é, penso que a cabeça tambem deve ser a do 1300GT, mas podes confirmar pela medida das valvulas.
    Fica aqui este link para tirares algumas duvidas:
    http://www.spridgetmania.com/web/SCatagory/CYLINDER%20HEAD/DisplayType/Calver's%20Corner/DisplayID/1526/ArticleV.cfm
    Espero ter ajudado
    Hugo
  16. Hugo Uriel
    26 Jun 2006
    Montijo
    Espero ter ajudado
    Hugo
  17. Hugo Uriel
    26 Jun 2006
    Montijo
    Espero ter ajudado
    Hugo
  18. Hugo Uriel
    26 Jun 2006
    Montijo
    Espero ter ajudado
    Hugo
  19. Hugo Uriel
    26 Jun 2006
    Montijo
    Espero ter ajudado
    Hugo
  20. Alexandre Batista
    6 Set 2006
    cascais
    Cabeça------ inlet ------ exhaust --------- cc ---------- models
    12G940* 1.312"/33.33------ 1.15"/29.2------ 21.4----- 1275GT, Austin 1300, all late A+
    models inc. Turbo but not MG Metro
    12G940 1.401"/35.6------ 1.15"/29.2------ 21.4----- Stamped '12G1805' on flat area by thermostat - MG1300, 1300GT & Mk3 Cooper S
    12G940* 1.401"/35.6------ 1.15"/29.2------ 21.4----- As above plus MG Metro
    12G940* 1.312"/33.33------ 1.15"/29.2------ 21.4----- Single point injection, also numbered 12G940B cast into head at clutch end
    12G940* 1.312"/33.33------ 1.15"/29.2------ 21.4----- Multi point injection, also with a number starting 'LDF10…' cast into head at clutch end and painted black
