Alguma Informação adicional
"There are no bad Pinto cylinder
blocks, but there are cylinder blocks
which can be regarded as better than
others. The later Ford Sierra 2.0IS
block (which has a small '205' marking)
has thicker sump rails than the
earlier blocks (Cortina, etc) and much
the same as the Cosworth 205 block
(which has a very large '205' marking).
There are no serious cylinder
block strength problems and, basically,
any 1970 on block can be used.
Sierra blocks (1986 on) have '165' cast in
them (in large numbers) for 1600cc engines,
'185 (in large numbers) for 1800cc engines
and '205 (in large numbers) for 2000cc. The bore wall
thickness is the same on all Pinto
blocks."
Espero que ajude
